Fuel injector advice
BigGez
Cairns, Queensland.
VY 3.8L Ecotec
Hey I just wanted to get some advice on my fuel injectors (VY 03 V6 ecotec) I think one of my injectors are a bit blocked up because when i put my foot down on the highway im getting a bucking/surging/hesitation feel sometimes, my coil packs are only a few months old, intake manifold gasket is fine, new fuel pump & filter, spark plugs are clean and i think the coil leads are okay. I want to give my injectors a clean and test but i dont know if its worth doing since a set of 6 is only like $130 on ebay, i dont want to buy $1000 bosch ones though, is it worth cleaning & servicing my injectors or should i try buy a new set? Car has done 260000 ks. Thank you all.
Fu Manchu
WA.
I’m redoing mine with a seal kit and bought an ultra sonic cleaner for my wife’s jewellery (and injectors) as well as an injector tester that pulses the injectors. $60 for ultrasonic cleaner and injector tester.
Sit them in the ultrasonic cleaner, hooked up to the injector tester so it pulses the injectors for a few minutes.
New filters and seals. Keep genuine ones running as long as possible.
  • Like
Reactions: Lex
