V
1991_Vn2nV said:Legal implication: Any forward facing bonnet scoop is illegal. If it has an opening it must face backwards, as in towards the windscreen...
:bop:
umm dude explain why they let subaru build the wrx then. my old hasnt been done in his rex for having a " foward facing bonnet scoop" think about it
silver_bullet said:umm dude explain why they let subaru build the wrx then. my old hasnt been done in his rex for having a " foward facing bonnet scoop" think about it
"The fitting of a rearward opening bonnet scoop is permitted without specific approval or inspection providing that the following criteria can be met.
a. Bonnet scoops manufactured from a plastic or fibreglass material may be fitted, providing that the hole in the original bonnet does not substantially reduce the strength or impact resistance of the bonnet and no rigid component, such as an air cleaner or carburettor protrudes beyond the original bonnet profile.
b. Holes may be cut in the bonnet and the protrusion of an air cleaner or carburettor above the bonnet line but below the bonnet scoop providing that the bonnet scoop or raised bonnet section is manufactured from equivalent gauge mild steel compared with the original bonnet.
c. If any bonnet reinforcing braces are cut or modified the design of the modified bonnet must be of equal strength to the original bonnet and any sharp edges created must be suitably treated.
d. All edges and corners shall have a radius of not less than 5 millimetres and of general design and construction so as to reduce to a minimum the risk of bodily injury to any person.
e. In addition, any bonnet scoop is unacceptable if it restricts the field of view of the driver under normal operating conditions. The field of view requirements are determined as follows:
• With the drivers seat in the rearmost position, it shall be possible to see, unobstructed for the full width of the vehicle, a line drawn on the roadway 11 metres ahead of the "driver's eye position" when looking over the bonnet scoop. For the purpose of this requirement the "driver's eye position" shall lie at the bottom of the of the 95th percentile eye ellipse (reference ADR 15/01 clause 15.1.5.1).
• Alternatively the "driver's eye position" can be taken as a point 750 millimetres above and 270 millimetres forward of the junction of the seat cushion and seat squab with the seat in the lowest and rearmost position.
The fitting of forward opening bonnet scoops, which have the potential to increase injuries to pedestrians in collisions, for example forward opening "letter box" style, are not acceptable."
