JamesSap
- Feb 3, 2022
- 30
- 8
- 8
- Age
- 24
- Location
- Australia
- Vt S pack s1
Hey guys,
My ecotec vt makes a sort of grinding noise after revving, as the revs come down right towards the end there is a grinding noise which lasts around 1-2 seconds, which is coming from the front of the engine. Sometimes on idle its barely noticeable, sometimes its not. It always happens when revved, doesn't matter if you barely move the throttle or go wide open. If revving harder though, the noise lasts longer, about 3-4 seconds rather than 1-2. All of the idler pulley bearings have been changed, new p/s pump, water pump, ac condenser and belt. possibly tensioner? was also thinking might be something more serious, like balance shaft bearing, maybe cam bearing? its definitely coming from the front of the motor. Any ideas would be much appreciated. Thanks guys
