sneaky
- May 16, 2022
- 3
- 1
- 3
- Location
- Brisbane
- VZ Commodore SV6
After researching for hours on end, I couldn’t find a single write-up on what to do about the whole “low beam turns off when high beam is on” issue when you go ahead and put projectors in an SV6 (VZ).
So, here’s the entire procedure!
What you’ll need
- Wire crimper and stripper (this one works just fine)
- A blade-type piggyback terminal (here’s the one that I used).
- A female blade-type terminal (here’s what I used)
- A male blade-type terminal (here’s what I used)
- Electrical tape
Method
1. Disconnect your battery; always do this when working on vehicle electrical systems
2. Remove the top part of your steering wheel trim and sit it to the side
3. On your indicator and high beam stalk, remove the large connector (there is a push tab to the right when it is sitting vertically).
4. Sever the WHITE wire from the connector and leave about 1cm of wire protruding from the connector.
5. Tape up the 1cm you left for safety purposes and to avoid exposed terminals/wires.
6. Strip the white wire that you just cut by around 7mm, and crimp on the female blade connector.
7. Sever the BLACK AND WHITE wire from the connector but make sure you execute the cut about halfway across the wire, because you’re about to attach two terminals to either side of the cut!
8. Crimp the male connector to the section that is now protruding from the stalk connector
9. Crimp the piggyback connector to the section that is coming out of the cloth-shielded vehicle harness.
10. Make sure all of your connections are secure by tugging on each crimped connector; it shouldn’t budge without a bit of force.
11. Connect the male blade connector and piggyback connector together.
12. Connect the female connector to the piggyback connector.
13. Re-connect the battery and test for a working low-beam; if it doesn’t work, recheck your connections. We test the system here before we tape it up to avoid having to disassemble our work!
14. Tape up your new triangle of little connectors and make sure they can’t wiggle loose.
15. Put the steering wheel cover back on and you’re done!
What you’ll need
- Electrical tape
Method
