db_notso
diagnostic technician...
- Oct 2, 2010
- 979
- 8
- 0
- Age
- 36
- Location
- sunshine coast, qld
- vt v6, mods(susp brakesetc...)
slip ring failure means
the code is not beinjg read by the slip ring
the signal goes through they key thats what the slip ring is for
take ONE key blade out and sand where it attaches with the remote (lightly so is clean)
reassemble and try again
if that fixes it then repeat to other key
if it doesnt fix it i suspect the memory section inside your key is playing up
try a locksmith or holden and get ONE new remote head fitted and programmed
if this doesnt fix it you have eliminated keys as a cause
unless the slip ring has been fitted incorrectly then a new one eliminates that (incorrectly like the metal on it should touch the key when in on position the ball bit on remote head)
if the slip ring is fitted correclty and key isnt at fault (which i think it is) then this leaves the bcm and the wiring from the reader to the bcm) more ouchies
butlike i said i reckon its your keys either battery died (age and coincidence) or memory board losing memory
