vombil
I have a 97 VS V8 which takes 2-3 turns of the key to fire when stone cold. No problem starting warm and drives perfectly once it's running.
I've cleaned the throttle body and IAC and also put a different ECU in it.
Interestingly you cannot hear the fuel pump priming when you turn the ignition.
I know it's a long shot but any takers? My gut tells me there's an issue with auto choke or TPS or something in the throttle body. It was 'hunting' too prior to me cleaning the throttle body.
I've had a commy give starting issues when it had fouled plugs. I suppose I should check them but yeah, it does not miss when it's running so I didn't bother looking.
TIA
TIA
