Car chucked air con belt when this thread started, March I believe. It was put back on straight away by air con guy and said it was mechanical, go see your mechanic. I drove since then with a wabbly balancer and the belt wasn't chucked once again.
Replaced balancer and belts and now within 1 week I just drove 50ks with Windows down as air con went warm. Belt wasn't on....
That's some kinda law, sods maybe but REALLY???
Will have it back on tomorrow in minutes, but I need to have a good look around tomorrow as there's been a knocking or dunno what kinda noise that is only really present when I start up and the choke is on and it idles at 1000rpm (which I've always thought too high). Once it drops to the normal 500rpm you don't hear it hardly. I always thought it was the balancer causing it but since finally swapping it out it has got worse, maybe whatever was causing it has give way, wouldn't be surprised...
Anyway, will investigate tomorrow...
Sure you can't wait...
