Headlight restoration
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
H
harrop.senator
Guest
2000 grit disc on low with an orbital. Soapy water on a foam interface , buff with a cut and polish wet and then clear them. I use Windex to clean before clearing , prepsol re fogs them
Boblet
73
marburg
2008 ve omega wago
for those contemplating..
tried the Utube methods ..toothpaste fail ....baking soda white vinegar..fail
the sand paper method worked , 800, 1000, 2000 grit with water , buff with rubbing compound using drill wool buff pad , polish with car wax , 1 hour for each light .
I use brasso with a pad on a drill. Cheap and effective. Maybe use a few times if bad.
Fu Manchu
WA.
It’s the shizz! Sand back in progressive passes of finer grit. 3000 last of you can find it. Then polish with Maguiars Plastic polish. Use a medium, then soft foam cone on a drill. If you have a DA polisher, even better. Then coat with the above to stop them yellowing.
Fu Manchu
WA.
Doing a plastic polish on a deteriorated un prepped surface is like cleaning the bathroom mirror with a pair of suss looking undies that have a skiddie in them.
59
QLD
VZ SV6
Hey guys, for a brilliant finish (and just 30 secs work) use Acetone and paper towel. You can sand them first if you like but seriously the finish will be just as good without it.
The process is simple
Clean headlights (optional)
Pour Acetone liberally onto paper towel
With a single smooth motion lightly wipe across headlight
Done.
The hardest part is maintaining even pressure and speed, not too hard. You be the judge.
The job was done on 15 April 2020
59
QLD
VZ SV6
Same light today, hmmmmm paint could use a touch up lol
  • Like
Reactions: Lex
