Heater Tap Problems
one_happy_panda
VX V6
Hi,
Diaphragm in my heater tap was faulty, so I replaced the tap with a new one. The valve is working as it should with vacuum, but no heat is getting to the other side of the tap. So the valve will be in the hot position, the hoses on the engine side are hot, but the hoses on the other side of the tap stay cold.
Any ideas on what could cause this and how to fix it?
Thanks in advance
losh1971
North Tas
VE Series I SS Ute
Did you accidently pull the vac line off the other end that connects to the tap? It's easily done.
one_happy_panda
VX V6
No, the vac line is connected both ends. No issues with vacuum, just getting heat to the other side of the tap.
losh1971
North Tas
VE Series I SS Ute
Try manually actuating the tap with your hand.
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
Might have to take it off and manually actuating the tap while blowing through it to see if it is working .
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
Faulty tap, hope not an evil bay special.
