digisol
- Oct 6, 2005
- 537
- 5
- 0
- Location
- Central QLD
- Toyota Landcruiser
If you have replaced the coolant it's likely an air blockage in the engine, simple as to fix and a common thing when the fluid has been changed.
I'm not sure if the VR has one but on the VS and later there is a brass bleed screw/nut on top of the thermostat housing, start it up and let it run until the thermo fan cuts in, loosen the bleeder and likely air come out at pressure before coolant does, lock it up, top up the radiator, fixed.
Of course if the bleeder is not there you have to half fill the radiator start it up and pour the rest in slowly, allowing the thermostat to open, if the water pump is not working you won't see the fluid flowing "as it should" into the radiator.
