Try both ways just can't get the plug up fingers to big looking at extra longnose pliers thank you for your helpNot easy. Can't remember which way I did it but only 1 way would work for me. I think I connected it first before screwing it in, that way there's more slack in the cable and I think I did it through the engine bay.
Or are you talking about the post cat sensor beside the transmission?
Hi, v6 standard or omega, even remove gearbox cross member try lower back of box and push across make a bit more room. The passage side level with gearbox pan the driver side up level with gearbox output shaft. Just brought extra longnose pliers wait till cool down. Thank you for your helpWhat car for a start and what engine?
On the LFW/LFX it's a bit of a pain as I have really big 4xl glove size hands but I manage.
On the LLT it's a **** show getting them undone and done up
Never tried on a V8 but most of them should be doable from up top or underneath you just have to get your fingers close.
Got it extra longnose pliers and bit of wire hook the plug in it goes thankyou for your responseNot easy. Can't remember which way I did it but only 1 way would work for me. I think I connected it first before screwing it in, that way there's more slack in the cable and I think I did it through the engine bay.
Go it extra longnose pliers and bit of wire hook the plug on it goes thankyou for your responseAh yes I know the one now. I had to rig up some funky piece of string or fishing line to reconnect the plug. Probably used pliers to squeeze the tabs in to disconnect it. 10 years ago, I'm just glad I only had to do it once
Got it extra longnose pliers and bit of wire hook up the plug on it goes thankyou for your responseWhat car for a start and what engine?
After all that, did it work? No more cel?Got it extra longnose pliers and bit of wire hook up the plug on it goes thankyou for your response
