HELP PLEASE Car shudders
Danielson1958
65
Mandurah western Australia
2012 ve equip wagon 3.6
Hi guys I have a bad shudder when I accelerate lightly or going up hill so under load I have had timing chains done replaced coils and plugs yesterday it still shudders and no codes come up or light does not come on had uni joints and center bearing
checked all ok anyone have any ideas please
It is a 2012 ve series 2,, 3.0 ltr equip sidi
Skylarking
123
Downunder
Commodore Motorsport Edition
Danielson1958
65
syked
Donating Member
2011 WM Caprice
Also might be worth checking the transmission mount and Engine mounts whilst you're there.
Fu Manchu
WA.
Could be the torque converter on the fritz if the other suggestions check out fine.
Danielson1958
65
Fu Manchu thankyou the mechanic did actually mention that last week I will be getting it checked out Tuesday or Wednesday and go from there if torque converter probly be expensive? just spent $2900 on timing chains coils and plugs supplied and fitted but cheaper than holden dealer thanks again Fu Manchu
Fu Manchu
WA.
Torque converters can be anything you want them to be.
The overall cost would be in removing the trans to get at it. (It sits in the bell housing between the engine and transmission).
Torque converters aren't cheap, but you'd be looking at $400 to remove the trans ($600 to remove a tranny, but some people might like her to stay). $500-$600 for a torque converter. Could guess at around $1200. A solid service would be required too.
Danielson1958
65
Hi yeah I was just thinking about it and read a couple threads and yours aswell which sounds like exactly what my car is doing so yeah I'm guessing I'm going to be up for about $2000+ thanks again Fu Manchu I let you know the outcome next week I'll go to auto trans place rather than my mechanic I think
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Maybe check the transmission fluid level as well.
