HELP PLEASE Car shudders
Danielson1958
65
Mandurah western Australia
2012 ve equip wagon 3.6
That sounds promising. Hopefully the transmission service did the trick
Well just been for a good run arround town and up the freeway and no shudder so seems like transmission service has done it just have to see how long it lasts thankyou so much for your suggestions and help very much appreciated
Danielson1958
65
I had a similar shudder only on acceleration, turned out a fine line cracked passenger engine mount, a common fault in commodores.
''Vin999, hi I had all the mounts checked and they were ok had transmission serviced and oil flush seems to have fixed it thankyou for your help much appreciated
syked
Donating Member
2011 WM Caprice
Good to hear it was just that and nothing major. A simple service can make a massive improvement in many cases.
Danielson1958
65
Maybe check the transmission fluid level as well.
''Imoengnr, hi I had the transmisi
Yeah absolutely pays to get services done keep the oils clean tho holden reckon those transmissions should be good to about 300,000 before a service hmm doubtfull but engine I think oil change every 5,000 with the ve
Danielson1958
65
''Imoengnr, hi I had the transmission serviced and oil flushed seems to have fixed the shudder thankyou for your help much appreciated
Danielson1958
65
Danielson1958
65
Torque converters can be anything you want them to be.
The overall cost would be in removing the trans to get at it. (It sits in the bell housing between the engine and transmission).
Torque converters aren't cheap, but you'd be looking at $400 to remove the trans ($600 to remove a tranny, but some people might like her to stay). $500-$600 for a torque converter. Could guess at around $1200. A solid service would be required too.
''Fu Manchu, hi I had the transmission serviced and oil flushed seems to have fixed it thankyou for your help much appreciated
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Not sure about the V6, but the V8 transmissions get new fluid and filter at the 150,000km service.
