go turbo dude thats where the numbers/power is at
She is pretty quick heaps of torque from 1800rpm I just know that there is another 30-50hp sitting in there restricted by heat and lift.
If i can drop temps by 30 odd degrees and grab another 25thou of lift bump the curve a little higher then hopefully they will show up.
So any one got some good second hand 1.7 or 1.8 rockers?
if you put a w2a with a seperate cooling system with an ice box it will be way better than any a2a. you could also put a methanol injector into the back of the throttle body to cool the blower then you can run more boost
