Alcyone
- Feb 25, 2016
- 174
- 3
- 18
- Location
- Victoria
- VY 2003 V6 Ecotec
I didn't mark the flexplate to crankshaft or the flexplate to to torque converter very well before disassembly. Everything is stock. So now I'm at a loss as to how to marry it up the way it was. The flexplate has a counter weight on it so I'm guessing that's important for balancing. Flexplate also has a small 'X' stamped on the back if that helps with alignment? Thankfully I didn't clean the flexplate before realising all this which means that there are 2 dirt/hole marks opposite each other around the bolt holes which marry up with marks around the back of the crank. This means that I will either put it on the right way or it will be 180deg out. I read that during engine balancing, the flexplate should be balanced with the crank etc...but it's got the same crank/cam/balance shaft etc. Only bearings, rings etc got replaced. I guess if I get the flexplate to torque converter bolted up and not aligned properly, because it only has 3 bolts, then it will only take another 2 goes to get it right! Pain in the butt to redo the flexplate to crank bolts when the engines in so I wanna make sure I get that right. Also don't wanna damage anything. How badly can I stuff things if I don't put it all on right? I'll take some photos in the morning to add here to show the flexplate and the 'X' in case that helps jog someones memory from when they did it. Engine is still out.
Also, do I have to get new flexplate to crank bolts? What about to the TC?
Cheers in advance
Cheers in advance
