Brett_jjj
- Oct 16, 2009
- 6,805
- 108
- 48
- Location
- Tamworth NSW
- vs commodore
My Hi speed circuit on the cooling fan wont work,the low speed one works though.It comes on with the AC,it comes on at half way like usual when sitting idling,but when I unplug the temp sensor wiring from the temp sensor it wont go from lo speed to high speed like it should,it just stays on low speed.It should(once disconnected) after 12 seconds turn on to low speed,then after around 6 seconds go to hi speed.I have swapped relays etc,no difference,checked the engine fan fusible link,all ok.I connected 12 volts to the fan,tried it on both pins in the plug and it worked fine.This one has me stuffed,am I missing something.
