jokerflingo
- Aug 16, 2008
- 1,048
- 2
- 0
- Location
- Adelaide
- Holden VY SS 2003 - 6 Speed Manual
Hey guys,
Sorry for repeating a common topic, but my Holden VY SS continues to throw up the occasional engine code which is really annoying even though nothing is catastrophically wrong.
Now it usually does this when it feels like it but normally its after a bit of a flogging on the slowdown back off eg right before a traffic light or turn etc. But it only does it occasionally eg i can sometimes do a trip of several 100km's and not experience it and then other times only a 20km journey and it'll throw up a engine code.
Now the obvious things to change are the O2 sensors and the oil pressure switch. I changed the oil pressure switch today, and it is a absolute bitch of a job and thought i had it sorted and dandy when i took it out for a test drive. Gave it a good flogging everywhere and nothing appeared, then 2 corners from home on a slight downhill coming to a stop holding its own revs being a 6 speed at the bottom up it came up. I was devastated but there's not point crying over it, obviously its something else.
Now this leads me to O2 sensors, but im reluctant to change them even though its easy as my old mans V6 commodore did have trouble with O2 sensors eg the engine code came up, he took it to Holdens and that's what it said, but the thing that's different is his would latch the error code, eg it would be there if you turned it off and back on and it would be there pretty much all the time, not like my occasional one.
Now this engine code, is it usually only related to these two common problems on the LS1 being the O2 sensors and oil pressure switch or can it also range to things such as lean condition etc and if it is does this normally latch or disappear because if i go through the dash screen to the trouble codes screen its says 00000000000 for all the numbers but my old mans said 0000100001 oir similar when he had the engine code which related to his O2 sensors. I should note my car has had a bit of work done by the previous owner but runs absolutely brilliantly especially with the lumpy cam, maffless tune and otr, pacies, exhaust etc, very drivable.
Any help would be appreciated before i go to Holdens and they charge me $100 or whatever to read a shitty computer and then another $100-200 for O2 sensors which i could buy myself and do easily. Mainly i would like to know if the engine code is meant to latch and if not can Holdens still read it?
Sorry for the long post but i always figure the more information the better and easier it is to help.
I look forward to any response and anyone who takes the time to read my annoying little issue which would be extremely appreciated.
Thanks
Matt.
Thanks
Matt.
