L67 Help!!
CookedVy
21
Commodore VY Ute 2003
Hello everyone, I’ve recently just put a l67 in my vy Ute. Got it to start run and drive, However, when I give it a little throttle in neutral or park it hits a dead spot and unless I pump the gas pedal it will stall out on me. Also when I’m driving and come to a stop it will stall out on me. Unless I keep my foot a little down on the throttle it will stall out.
I’ve done a
boost and vacuum test, both passed, checked the tps sensor, that was fine, checked maf sensor which was fine
Checked fuel pump and filter, both fine
Check AIC, which was fine also
When I put a scan tool in I got a o2 sensor code for left and right and leaning out on high load, both o2 sensors were getting around 477mV as detected by the scan tool but then said both o2 sensors were “Not Ready”
Anyone know why? Could that be the reason for the dead spot in the throttle and the stalling when stopping?
Immortality
Staff member
Sth Auck, NZ
Manual or auto?
Have you changed the the tune to suit a supercharged motor?
CookedVy
21
Manual or auto?
Auto, yes, I’ve had it on the dyno just to get it to a point of where I can drive it to and from places as it’s got a bit of work done to the motor. The dyno place said they tried to tune it out but had no luck
Motors had done
A2A intercooler
20 thou pistons
20psi pulley
Ported heads
Ported charger and snout
Yella terra snout
82 deg thermostat
5% overdrive pulls
Immortality
Staff member
Sth Auck, NZ
Where is the MAF placed?
Tuning MAF with a full A2A setup can be troublesome.
Immortality
Staff member
Sth Auck, NZ
That is most likely your issue, there is a huge lag between what the MAF is measuring before the blower and what is happening after the blower, through the A2A and into the LIM. There is one guy I know who's had reasonable success MAF tuning a similar setup and I'm fairly sure he's moved the MAF so it's after the A2A going into the LIM IIRC.
Unfortunately all his stuff was posted on the old L67 Torque forum which died a while ago so I can't bring up any of his build thread to reference.
CookedVy
21
Kinda understand what your mean, but what do you mean by LIM IIRC?
Immortality
Staff member
Sth Auck, NZ
Lower Intake Manifold
If I Remember Correctly
Actually. I've been looking back over some old stuff. He might have had it in the stock location but he ran a A2A/W2A hybrid setup which has much shorter piping.
The user is/was @0081 but I don't think he's been online in very long time.
CookedVy
21
Ahh right ahaha, would you know the reason for the o2 sensors not working? They are getting a mV reading but say “Not Ready” for LH and RH on scan tool
Immortality
Staff member
Sth Auck, NZ
What scan tool are you using?
O2 sensor not ready is normally during cold start. Engine has to run for a period of time before they are up to operating temp.
