PIR4TE
Banned
- Mar 15, 2011
- 2,747
- 74
- 0
- Location
- AWOL with Ari
- Black Pearl
Apparently the OP has an MY9.5 L98 with flex fuel, I checked into that.i didnt think you could run E85 in the older VE's as the newer ones had a different fuel system setup to cope with the extra ethanol content and the extra fuel it uses. can anyone clarify this?
you can use any type of unleaded fuel, but it'll run better on premium and you'll use less as well. there isnt really that much difference dollar wise when you compare cost vs economy
Agreed, that video I posted is worth watching when you get the chance.
A lot of people are put off e85 because basically it takes on moisture and you need a stainless / plastic fuel system so not be affected by scouring in the lines or rust through condensation. Can't use e85 in a boat or plane!
I've read conflicting reports that the ECM calculates flex fuel calibrations without the special flex fuel sensor as well, but conversions sell it?
Don't listen to the numbnuts at servos who warn "you'll use 25-30% more" as it really depends on how and where you drive - I get 100km less per tank - still works out cheaper for me - $10.45 per 100km versus $15 on 98.
P100 is the best in dollar terms for mileage / tank, very close to e85 in performance.
Only dramas I've found with condensation in ethanol is buying a mild steel catback that's turned religious (holy) in just over two years, and when you mash the pedal in winter morning or night there's a high dewpoint a cloud forms for about two metres behind the car like Batmobile's smokescreen generator and you have to put the rear wiper on.
United will give you close the 85% alcohol whereas Caltex is *up to* 75% I've found (I make wine so I pack a hydrometer).
Oh and if you are going to the snow it makes it difficult to start, then runs like a 'vette wagon with a SuperChiller.
The whole e85 thang helps get approval from Domestic Finance Ministry as well..
