All depends on how loose the housing is, I use them to stop any rattles, it also helps keep the pads in place..Well i have never seen them on any car i have owned, so must not be a necessity.
Still salty after the Tigers destroyed you in 2017 grand finial. If people stop rubbing me up the wrong way first then I wouldn't have to defend myself.Honestly Trev, why don't you go to another forum where your style is more appropriate. It seems that all you do is rub everyone up the wrong way here. I'm sure I'm speaking for many here that share the same sentiments.
Holden Commodore Vt-VZ Front caliper slide pin kit
See the 2 anti rattle clips.
I'd still be careful, you never know with old stuff what might still be fitted.
That's true. Some just kill you faster than others. Minerals, ceramics and metal are really bad because they stay in your lungs forever and slowly reduce your lung capacity. But rubbing brake pads on the ground doesn't fill the air with dust though. Tools like angle grinders, saws and Sanders are the worst for that.Any kind of dust is bad for the lungs. Avoid it wherever possible and wear a mask.
