why do you need to use the foam, why cant you glue straight to the lining, from what ive seen the foam then material doesnt turn out any where as good as a trimmers job, i got quoted 280 to do the job and i pulled it out and got another quote and they said 180 LOL
is the best result just to glue it straight to the lining or get heavier material or something with backing on it and use that
good thread too very informative
The problem with putting the new material straight onto the board is that the board has little dimples in it. If the material you use is thin it will look hideous. IMO its MUCH easier to go straight to the board (applying glue onto the foam is a pain in the arse), but you have to choose a material with a very thick backing.
heyyy how did u do the door trims? can u say step by step thanks
Some door trims cannot be done. The easiest way is to go and look at your cars door trim. There are 2 different types of door cards, door cards that are held in place by stables (i think) from the back of the door trim and door cards that are "welded" in the door trim. It is quite easy to distinguish which yours is by simply looking at it.
If you have the type that is welded (from memory VR series 2 and onwards had this type) you cannot change the door card, unless you find a complete new door trim, or cut up your current one.
If you have the removable type its quite simply, all you need to do is take the door trim off and it will just pop off from the back.
Also, for anyone look for material I highly suggest looking at:
http://www.nolans.com.au/
