That is all salient advise.
But when you do the same thing every day for as long as I have you get experience, so you know what is going to happen before you even touch the thing you work on.
In some cases experience can be the killer as it creates a false sense of expertise.
One of the interesting Air Crash Investigations episodes was a relatively simple windscreen replacement on a Boeing aircraft. The aircraft mechanic removed the windscreen and using his experience he knew exactly which bolts the ones he removed were, so he replaced like for like…
The unfortunate and near deadly problem was that if he checked the Boeing documentation, he’d have realised that at the previous windscreen replacement the mechanic used the wrong bolts! It was just luck the previous windscreen didn’t blow out but this mechanic wasn’t so fortunate!
The end result was that the windscreen blew out on approach to LHR partly sucking the pilot out the opening. If it wasn’t for another person within the cockpit that grabbed the pilot and the skill of the copilot to slow down and land the plane with his off sider hanging outside, the pilot would’ve be dead… because the aircraft mechanic had been working on aircraft his whole working life…
This is not meant as a dig at you, more a general warning that **** happens and we can all get caught out if we are complacent because we are skilled…
