thanks a heap
That must be how mines is set up,is it revurse to get it so i havee to use the black dongy to start the car as i wouldnt mind using that way,and 1 more thing? Do i need the red tag to do it
try the instructions below for disarming the iss - may not work on vs3.
Service / valet system override
to put the immobiliser into system override mode, first ensure that the immobiliser is disarmed and the ignition switched on. Press and hold the tag against the recess in the status monitor. After three seconds the led will start to flash quickly. The led will continue to flash quickly to warn you that immobiliser is still in override mode. Once system override mode has been entered, the immobiliser will remain in this mode until the tag is touched against the recess in the status monitor.
thanks a heap for you reply well done
so how many tags would the car have come from factory. As mine one has the one black tag. Can new tags be ordered from hsv
3<<<<< 2 black and 1 only red master tag
also where were you able to buy a new one from. Does hsv still supply new iss kits
you cant get them any more.......i know of a 1 series 2 brand new unopend kit with everything in it that i can get,,,,,but that wont fit into my series 3 from what i know
you won't have a problem getting a new key head. The iss system (black/red dongle) and the remote/key are separate from each other (assuming you have the connector in the centre console/arm rest). For models such as the vx (not sure about the vt) the iss is integrated with the normal key/remote. Note that the key part (metal) can be attached to the new remote, you don't have to get a new key cut (although most places, such as mister minute, also cut you a new key).
it said in the hsv man on iss that new key heads must be intoduced with the red tag.....i can still turn the iss off with the black tag,but to introduce new keyheads or black tags i must have the red tag to put the system into learn mode>>>>you may stilll be rite and im reading the book wrong>?? But from what i can gather i need the red tag to intro a new keyhead to the hsv iss....if im wrong( i hope i am ) please let me know...best wishes.thanks for the reply
