JBAV6Tony
- Oct 15, 2016
- 93
- 21
- 8
- Age
- 68
- Location
- Strathbogie Victoria
- JBA kit car V6 series 1
Members might recall my S1 V6 manual in my kit car JBA Falcon. I've had many issues over 3 years with the IAC. Some time ago I read articles here. So I renewed the IAC but alas couldn't afford a genuine so ebay was the answer.
Still had issues. So took it out again and as soon as it was lowered down the pintle and spring was loose eg not screwed into the plastic housing. In fact it was wedged in. So it had come loose and was on an angle. Anyways I screwed it on again by not very much say two complete turns. This is because although it adjusts itself it has to strike the top of the peak of the unit to make a seal so it turns off when not needed.
Test drive, get engine nice and warm and still sucks lots and doesn't want to reduce idle speed. Read in this forum of advice to slowly place finger on IAC intake inside throttle body then obtain a 600rpm idle just above rough idle. Idle was still too high - why?. throttle idle screw under sprung throttle plate was jammed. Took plate off and WD40 plus vice grips! and finally it was loose to adjust but the screw had been screwed all the was in eg maximum idle adjustment= high idle. Replaced sprung plate, repeat procedure, idle lowers down to 600rpm. Idle a little rough and some sucking noise, looks like IAC is working trying to keep idle higher. Adjust screw in this time till rpm reaches 700-720 rpm. Sucking vanishes, idle perfect.
Wait for it to cool. Next day start up cold engine. Idle isn't 1300 but 1000rpm. Nice. Wait for 2 minutes it begins to slow down to 700rpm, now sucking from IAC eg pintle is up to the top (extended). Went for a drive. Normally I'd return and idle would be 1300rpm now 700rpm and no sucking. Rev engine high then close throttle, engine quickly falls to 500-550 rpm sucking comes in for 5 seconds, raises idle to 700rpm then sucking stops. If that is how the IAC should perform I'm very happy. All this IAC adjustment stuff and replacement all because some fool screwed in the throttle stop all the way in. That meant the butterfly was always open too far for the IAC to operate as it was meant to.
Thanks to those that made the IAC a topic of discussion. I hope others can benefit.
Here is my caravan I built, recently finished. 16ft x 7ft with full ensuite ATM 998kg. All lightweight, steel tube frame, 4" drop axle, heater aircon etc.
Tony
Tony
