Lex
- Sep 19, 2012
- 6,205
- 5,669
- 113
- Location
- Geelong Victoria
- VT Executive S1 V6 6 speed Auto Wagon
I got it for about $65.00, in feb. 2013, if l remember correctly.edit: just checked online, I should be able to get all the bits for under $100
Not sure of the plugs you are referring to here?but first I'll check I have the plugs in the bay and under the steering column to plug
Everything had to be taken out of the donor cars' pcm & bcm.
Can't remember if the plug for the cruise c under the steering column is already there, or if the wiring from the pcm or bcm when that is wired in, then you have the plug?
