Intercooler with Supercharger - Needed? give your opinion
JA2Z
East Gippsland, Vic
www.studiomarban.com
VT 5L, WH LS1 Stato (Daily), TDCi Focus, Probe V6
Hi,
I have put an intercooler on my VR V6 Commodore that i S/C (the intercooler can in the kit). Although i does look MEAN:yeah:, I undertand what their function is but it doesn't seem to do much for the performance other than cause a bit of lag.
What do you think about intercoolers with supercharged motors?
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
anything that keeps your car cooler is never a bad thing mate. Just because you arent noticing a difference doesnt mean its not extending the life before it blows up.
Chris E
Vr Executive 3.8
I was under the impression that you could run higher boost pressures with a intercooler? Or that after you went over a certain level of boost you needed one. Not sure though, I'm sure someone more switched on will shed some light.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
if the plumbing is too big you will get a lot more lag also depends what pulley youre running.I presume its an SC14.with the cooler you can run more boost and run a little more timing and fuel
stocky
37
if youre only running 4 psi, then yeah, you wont notice much. higher boost it definately helps
HARVZ-6
Riverton sa
VT spac super6
running the cooler is deffinatly worth it
allows you to run higher boost without detonation etc
no its not needed, but it all helps
if you want to feel hte affect more.. up the boost :p
JA2Z
East Gippsland, Vic
Ok. thanks.
Next question:
Is there a significant disadvantage to plumbing the intercooler to the intake of the charger?
I understand the compressor air heat effect generated within the SC (resulting in slightly higher output air temp) but if that temperature can be reduced prior to entering the SC, will that give the same effect?
That would allow you to run a much larger tube straight to the manifold (i.e Zero Lag). And enable me to facilitate the use of my CAI correctly by plumbing that to the IC inlet
Anyone experimented with this?
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
I think the problem with that is the supercharger generates a bit of heat so if the air is getting cooled before the supercharger rather than supercharger-intercooler-engine, the air will get re-heated again going through the supercharger.
JA2Z
East Gippsland, Vic
Ok, cheers.
Well i've bought some 3" Stainless Tubing, i'll plumb it up when this other TB arrives that i've ordered to mount infront of the SC and let you know how it goes.
