Darren_L
- May 2, 2009
- 1,872
- 73
- 48
- Location
- Toowoomba, Qld
- VH SS
changing the cam isn't a big job on it's own, in fact a 202 is one of the simplest engines to change the cam
the problem is, it's an EFI engine with an old analogue L-Jetronic ECU. There's no 'chip' or memcal that can be easily swapped/tuned etc to suit the new cam profile. So really you'd need to change the engine management system so that you could tune it. If you swapped the cam without a tune, the engine would run like crap and/or use even more fuel etc
And yes the EFI 202 did come out with a fairly decent set of headers/extractors, so I don't think you'd see much gains by replacing them with pacemaker.
So in a nutshell, there's probably not a lot you can do with the EFI 202's, without upgrading the engine management system. If you are serious about it though, there is a really good thread on the Delco Hacking forum about converting the EFI 202 to a Delco ECU.
