Nut Kracker
Donating Member
- Oct 18, 2012
- 4,760
- 150
- 63
- Age
- 64
- Location
- Echuca Vic.
- VT SS 304ci (195i)
Well, the place I took it to couldn't access the ECU with their test equipment.
May be due to the Kalmaker tune.....I dunno. It didn't play up for them when they took it for a test drive, nor did it for me when I picked it up this afternoon.
They checked the engine for vacuum leaks, binding linkages and throttle cable etc.
and that was all ok.
It did play up a bit this morning though, before I took it to the Mechanics, as it wouldn't return to idle while driving.
Cold start idle seemed ok at first, but then slowly crept up to around 1500 rpm.
I stopped the engine and restarted it and the idle was ok.
One thing I have found though, is that when the idle was high when driving this morning,
it would suddenly drop back to normal idle, as if the IAC was closing and then return to high idle, then back down again.
All this was in the space of about 10 - 15 minutes.
I did replace the IAC about 12 months ago, but it was non genuine and I'm wondering if it is playing up.
It seems to me that this is an intermittent fault and associated with the IAC.
Opinions.......?
If it was a fault with the tune, wouldn't the high idle be there all the time?
Also, the temperature gauge seems to be reading lower than normal.
It has always sat half way between quarter and half, whether it's -5 or 45 degrees.
But it is now it sits just above quarter.
I know the IAC (amongst other things) depends on readings from the temp sensor.
So I am also wondering if this is also associated with the problem.
They are not an expensive...."lets see what happens if I replace them" option.
I might replace the temp sensor first, as that's the least expensive of the two.
And I will be going genuine on both, if I need both.
Opinions.......?
