mindedrobin
- Sep 17, 2023
- 7
- 3
- 3
- Age
- 24
- Location
- Australia
- VY Commodore Executive Series II
My Series 2 VY Commodore has lately been having issues with its idle. This issue starting with a high idle about 1500 rpm about a month ago. Where then I cleaned the Throttle Body and replaced the IAC and Throttle Position Sensor, the only code on the car was an abnormal idle code. Then the car appeared to drive fine for a short time. Then the high idle returned, I then found and fixed 2 vacuum leaks using a smoke tester fixing leaking on the hoses from the EGR and the Charcoal canister to the intake. This did not solve the high idle and it then developed into a high and or low idle in the car, the old and new IAC we both tested and read 50 ohms across the a b and c d pins and no continuity between the pairs which is what the manual says is within the expected resistance.
Then the car developed into a only low idle where the IAC would go to 220 steps and cause the RPM of the engine to fall down to 300-400 rpm when not on the accelerator and at one point stalling the car while braking. But besides the 1 time it stalled the car would manage to idle at 400 rpm but this issue only seemed to appear when the weather was warm, on cold days the car would drive fine and warm days or afternoons the issue would appear. Now the car goes from starting perfectly fine and driving perfectly to then a high idle, then to stalling itself when trying to start.
Then when it would start the idle would be low then if you accelerated it would then stay at 1000 then if you accelerated again it would go to 1200. And though this all there have been no engine codes besides the abnormal idle after the car idled high. The intake air temperature sensor was the next thing I expected but it read the correct air temperatures. This issue only seems to happen when the car is in taking warm air. It has been tested for vacuums leaks when cold and at temperature having just been run. I have no idea what is causing this issue now.
