Skylarking
- Feb 3, 2018
- 10,123
- 10,579
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Which was exactly why I initially thought a blocked oil screen under the oil sender but that’s only V8 thing and only for AFM DOD (VLOM filter) equiped engines, so not relevant to V6’s.The thing that caught my attention was, the knocking noise was there then disappeared after an oil and filter change...It then re appeared....
Maybe it has some crud stuck in a lifter or two? That's where I'd be looking...
Maybe even do an engine flush to clean all the crud out and see what happens from there
I think a video with audio from a mechanics stethoscope would be the best at trying to track down what’s the cause of the noise… but not so easy to make…
Otherwise whatever lives in the read left bank of the V6 may be the cause. The fact that the noise follows the speed of the engine leads me to think sticky lifters because purge valve noise shouldn’t be linked to engine speed (one would think)...
I worry about using engine flush in vehicles that may have had poor oil and oil filter change routines because lots of crud may have built up internally and oil flush can loosen it so it moves around and blocks more things?
But there are many threads on the subject of oil flush and some like to take the slower diesel oil route with a few speedy oil filter change every few 100 kms(?) and an oil change at 500 or 1000 kms (?) from memory… then repeat a few times… why diesel oil, because it has more cleaning agents/additives within… but it’s costly in cheap filters and oil…
+ 1 for a video as a first step…. and a diagnostic scan to show current and saved DTC’s can’t hurt…
