L67 Fuel & ECU questions
Scrubzee
Vu series 2
Hi guys,
I have purchased a l67 to fit into my vu and was wondering what aftermarket fuel pump people are running for them and also would it be worth running an aftermarket ecu or will the stock vu ecu be fine with a tune
I’m planning on performing the following mods
Stage 2 cam from MACE
Water to air intercooler
3.2” 12psi pulley
Comp style pacemaker headers with custom split 2’5 exhaust with x pipe
Possibly bigger injectors???
Upgrade to ls1 fuel lines from tank
Cold air intake
Any further suggestions and advice will be greatly appreciated
_R_J_K_
Zenki S14
You should be able to put an L67 memcal in and be fine. Generally there aren't any aftermarket ECUs that support the 4L60e (if yours is auto) bar for a few piggy backs.
LS1 fuel lines are a waste of time. I don't believe they're any different, and even if they were you wouldn't max them out. Fuel pump on the other hand is different for a Super 6, so you do need to replace that.
Cam and bigger injectors need a tune. Tune is advisable to get the most out of that pulley (generally people don't go above 10 untuned). What specs are the cam? ("Stage 2" doesn't mean anything)
Scrubzee
Vu series 2
I will be running it behind the 5 speed getrag.
This is the camshaft specs. Using the stage 2 cam.
Any advice on what fuel pump to use
chargedvp3.8
22
Vp commodore
E85 to 98 octane Flex fuel kinda thing is it possible to run both
Immortality
Staff member
Sth Auck, NZ
Not on a factory PCM.
Immortality
Staff member
Sth Auck, NZ
.... PCM.... PowerTrain Control Module. aka the ECU that controls the engine and transmission.
  • Like
Reactions: Lex
chargedvp3.8
22
Vp commodore
You can't do flex tuning on the factory ECU. It's either tuned for petrol or tuned for E85, one or the other, nothing in between. Having "switched" tunes isn't really a thing either.
Yeah obviously not factory ecu that won’t work I’m talking as in after market like haltech for example. And having more than one tune on a heavily modified car is definitely a thing I’m pretty sure you wouldn’t wanna be hitting 31psi with the gate wide open on the street they call it a safe tune and then you would have your track tune for drag racing or drifting or whatever tickles your fancy
_R_J_K_
Zenki S14
Information that would have been worth mentioning in your first post. The GM Platinum Sport plugins from Haltech will do flex fuel with the addition of their CAN expander, and their Elite ECUs will just do it natively with regular loom connections I suspect. Their ECUs don't have the ability to control GM electronic automatics so it's manual only for them unless you get a transmission controller.
Just about every good ECU brand has flex tables as standard now and can advise on the flex sensors to use with their ECU.
Because you gave no context, I just meant not for the stock ECU.
  • Like
Reactions: Lex
