Luke VY L67
- Jan 28, 2018
- 10
- 1
- 3
- Age
- 41
- Location
- Pimpama
- VY S1 L67
Hi,
I just purchased a 04 VY L67 with overheating problems.
When I purchased it the rear hose had a split in it which comes from the thermostat housing.
Since then I have replaced the hose and the thermostat which I tested and was not working. I have now flushed the radiator and replaced the water pump and the radiator cap but I'm still having issues.
The car seems to overheat while the car is stationary.
The Thermo fan is working and running in the correct direction.
Both hoses are getting hot and seem like a similar temperature. The pressure builds in the system from idel yet the radiator cap stays at a much lower temperature. If I depressurise the system by opening the cap slightly then the temperature will drop temporarily.
I have looked at other replies and I'm guessing the LIM gasket could be the problem but wanted to see what other people thought before pulling the motor apart.
There are no normal signs of a blown head gasket as the coolant and oil seem fine and no mosture from the exhaust.
I haven't seen any coolant leaks at operating temperature.
I have bled the air out of the system multiple times to try to insure that there's no air locks.
I would appreciate your feedback as it's doing my head in.
Regards Luke
Regards Luke
