jonathon
Question to the Holden Gods .
THE BACK STORY
Three days ago the misses started the Wh and smelt something burn for a second or two(continued to drive). Day 2 short trip to shops , return car will not start.
My first thought regulator as when I tested battery it was down in the 9's and after jump starting voltage was going no where fast.
Now after changing the regulator (did nothing Bosch part) swapped with another from a vx we get a rising voltage (on a fresh battery) followed by the alternator heating to a point in which i smell winding burning, and the unit temp is way out of touch range .
Now after replacing the unit with a new fitting im having the same 0-f_ing hot alternator in 3mins issue , at which point I'm looking for short or bad connection issue.
Where is the best place to start , i have pulled loom apart from battery to alternator both the voltage sample and alternator output cables test .1ohm from terminal to terminal. Cleaned all these before putting back together including all the connections onto battery
Does anyone know what the normal operating temps for an alternator with just running car load (no ac, lights in or out , stereo)?
THE BACK STORY
