Allot of people are researching LPG so I would like to add to this post.
I have just installed an Orbital Liquid LPG system to my fiancée's 2009 VE SS. Why? Now we have a family car that looks good, sounds good, has loads of power, is fun to drive and now is fuel efficient. With fuel prices soaring to 160+ a litre (and that's just for E10) it made sense to me.
I chose orbital as the car will remain pretty much stock (except as I have done now - got rid of the rear mufflers). I also did some research and it appeared to be the system with the least amount of problems and best customer service. I also chose the doughnut tank in place of the spare wheel. I got hold of a space saver for the longer trips away, but am going to get a compressor and can of goo for the short trips.
I will obviously need more time to evaluate the system, but there is no real difference power wise between gas and fuel, if anything the LPG is smoother and has more low down torque.
This is not the first car I have had converted to LPG. I have now had mixer (venturi) style, gas injection and now the LLi. The LLi is more superior to the other 2, and is worthwhile now it is only a couple of hundred more that gas injection. If it were say $1000 difference, I would have gone with gas injection.
Venturi/mixer style LPG on EFI cars is rubbish. You loose power and expose your vehicle to potential long term engine damage.
My suggestion to people is if converting your car to LPG, make sure you chose an installer who specialises in LPG, I test drove a 5.7L LPG statesman the other day with mixer style LPG that was a disgrace to an otherwise beautiful car. Avoid people who say your car is rubbish or they won't touch it - sign of an incompetent LPG installer. Think about where you want your tank - I chose mine as I can still use my boot and on long trips can pack stuff on top of the space saver. I can also still access the boot from the rear seat.
Now the system I have is an orbital series 500. I have not had any issues filling the car and it doesn't revert to fuel at high RPM or load. The system cost $4600 installed with a doughnut tank. This system does not require special LPG oil or different spark plugs like other systems can. And the rebate $1000 is still available.
