Make sure that you blead the Air out of t he L67 Cooling systems,
There is 3 Bleed points,
- On the Radiator Return Pipe
- Under the Snout
- Under the Air intake Elbow, [under the Boost Valve]
Air lock in the L67 cooling system can do exactly what you described,
I put Anti Freeze/Anti-boil in and was able to see the colour of the water coming out when bleeding it, especially on the back one.
Don't unscrew them to far [say half a turn], because if they fall out,
you will be saying a few extremities, because you wont be able to find it.
To push most of the air out when its cold, open all 3, then place the hose in the radiator filler, with a little bit of water pressure by placing a rag around the hose on the neck of the radiator filler, and it will expel/push the air out the bleed holes, then tighten them, and get it up to temp, and open them again one by one.
Let it cool down and check the water again.
Hopefully that will fix the over-heating issue.
My temp gauge ALWAYs sits just under half way, on Hot and Cold Days, even with the Air on stinking hot days.
