Well just tested the ute and from a standstill it will spin both wheels. I actually had to back off, because I'm not wearing out fairly new tyres. However there is a problem with the TPS. It won't kick down to second from third. It will go from first and change up through all four gears. But stab it and it will stay in third. Have CEL when flooring it, which goes away after 5 or 6 seconds. Code 21 is logged. New Delphi TPS and installed correctly as I just checked. I didn't think it was right since fitting the new sensor. It played up and had to limp back home, 3km as had no gear changes. Pulled sensor and engine fuse, reassembled. Now have gears but no kick down, still and still get CEL at WOT.
