BlackVXGTS
- Aug 14, 2004
- 5,504
- 2,517
- 113
- Location
- Melbourne, SE
- GEN-F2 GTS A6, VS Clubsport 185 A4
Just started getting a loud clicking noise from my right hand front wheel when turning corners on my Gen-F2 GTS (48,000kms), particularly noticeable at roundabouts and when turning into parking spaces. No rumbles or other noises when driving straight ahead (at any speed). I have:
Problems requiring replacement rear wheel bearings seem to be a not uncommon occurrence for VEs, but there are few (if any) posts for front wheel bearing problems in either the VE or VF forums. I’d appreciate feedback from any forum members having similar problem, and in particular, details of the resolution.
- Jacked up the front, both wheels turned fine, no noises when steering turned left or right.
- Checked the wheel bearings, no play top to bottom or left to right.
- Removed the RH wheel, checked all bolts in the suspension and brakes for tightness, all OK.
- Nothing stuck in the tyre.
- Couldn’t see any signs of rubbing anywhere.
- Brake pads are a little low, but still have plenty of pad there (not that the standard pad material is very thick to begin with).
- The wear indicators are still a couple of mm from the pad material.
