LS3 Cam and valvetrain upgrade
Maloo 176
37
Germany
E3 maloo
I think i know what im going to buy.
The comp cam's 54-448-11
- btr Double springs Titan retainer
- yella Terra 6667 Roller Rocker
- Johnson short travel Link bar lifter
- ferrea 6000 2.200 Intake and 1.600exhaust valves
What pushrods should i buy when I know length. Read about manton Serie 5 11/32"
Will that work together?
Im still looking for a steam vent kit that fits stock ls3 Intake. Front and rear...or crossover?
07GTS
Australia
VEGTS BUILT BLOWN E85
the valve sizes are not a factory size and will take alot of work to fit pretty much worth just going an aftermarket head with those sizes already, u cant just fit bigger valve in a head, u wont see any gains with those valves u would be better keeping stock valves and just getting a cnc port job and get actual gains, manton or trend do good pushrods just check the size that will fit ''diameter'' as not all heads allow a bigger diameter pushrod
Maloo 176
37
Germany
E3 maloo
Now i think thats it....
- Cam i have (Comp Cam 54-448-11)
Thats my shopping list:
- Fly Cut Tool in and exaust valves
- Johnson ST2116LSR
- good pushrods maybe 11/32"(after knowing length)
- yellaterra 6667
- double spring Kit AFR8017 Kit Titanium retainer
- ferrea 8x F6280 8x F6235_1
- head gaskets 0.30
- fel-pro intake gaskets for matching Intake to head
- Headers gaskets
- gaskets for waterpump and Timing Cover
- pulley screw i can use more than once, earls?
- head Bolts i can use more than once, arp?
- Steam vent Kit front and rear (crossover?) that fit Stock ls3 intake, maybe 2x GM Stock 12694769 use
in Front and rear?
