Mate when I was talking to one of the Holden mechanics he said that most of the earlier aluminium motors were noisy. They tried pistons with longer skirts, to fix some of the louder motors, with limited success. With the modern computer technology and precise methods of production, why it would affect some engines more than others is
puzzling. I could understand it to some extent if the problems were only with the high performance motors, but ours is a standard 6 litre.
By now it has become apparent that GM had quality control issues and excessive piston to bore clearance are the result, or worse, they simply did not care (it's a "performance engine" after all and they are noisy right?).
A quick online search says the LS3 motors use a Hypereutectic Cast Aluminum Alloy piston. The whole point of using this specific material is that it expands less with heat allowing closer piston to bore clearances and quieter engines.
LS motors were also really bad for burning oil in the early days ( and didn't really ever fix that problem either). Short piston skirts, low tension rings (to reduce friction and improve economy) and it all adds up to a recipe for disaster.
I know an ex Holden tech who used to do the rebuilds on LS motors for cars that came in for warranty work for burning excessive amounts of oil. Rip **** and bust, get it done and then take it out and run in the new rings
Other manufacturers can build quiet alloy engines so GM is just full of ****.
