My suggestion is don't ignore the noise as if lifters the earlier repaired the less collateral damage done.
I was told the Police have had a lot of lifters replaced
in and out or Warranty by GM Australia - same problems different GM attitude to repairs.
My own LS3 cold noise was identified well within Full Factory Warranty and the resulting legal case continues today with GM Australia refusing to follow QCAT directions to provide diagnosis and file info. In my experiences no one other than GM Australia has identified the noises linked in my video below as normal or characteristic of a 38,000km LS3 (not even Holden Dealers). The bullying and extent GM have gone to to cover up this 'noise' is intended to be exposed after the hearing (always says something when Manufacturers override its Dealers diagnosis (especially without even inspecting the noise or employing deceptive practices)). From statements by 'LS3 experts' I have been told, LS3 hydraulic lifters can fail at any traveled distance - many allege this is a GM Manufacturing Quality Control issue or in other cases a servicing issue that can trigger it.
70,000km appears a traveled distance some others report the noise was first noticed - beware the problem could have existed earlier but the noise not heard at idle (see video below it can come in and out) - the durability of any engine is dependent on the weakest component and not expected at low kms.
Most LS3 engine owners may be unaware of what is likely could be costly problems developing in their engine. If people concede to GM rhetoric and take excessive noises as 'normal', take unsubstantiated claims by those with a conflicts of interest at face value, or choose to ignore such noises: (which, with lifter problems Holden Technician's stated could start at any time) they must also accept that engine damage to lifters, camshaft ... is acceptable and could cost $5000-15000 to repair later down the track.
The recorded noise I experienced (many many similar videos) were recorded at idle then within the first few minutes at idle then around 1200 rpm. I was advised by a experienced repairer that the noise he heard in my engine will develop into a cold and later warm engine noise as damage progresses. I am not alone saying that GM and the 'industry' are well aware of this problem which GM want to hide owner awareness of (appears prepare to loose a one off Holden customer to save a alleged recall and impact to other GM products about to be released in Australia).
[/URL]
