and then what ??And then??
And then you shared your solution so this thread can be useful to others that face the same problem. Alot of people ask this forum for solutions and often don't return with a conclusion.and then what ??
ok, sorry ..... I made up some "extensions" using a block of mild steel. I cut a groove in it with a plasma cutter which will sit over the body seam where the lifting point is. This allows me to jack the car up without busting the skirts. As for servicing, I have found someone that'll let me use his 4 post hoist.And then you shared your solution so this thread can be useful to others that face the same problem. Alot of people ask this forum for solutions and often don't return with a conclusion.
Any photos ?ok, sorry ..... I made up some "extensions" using a block of mild steel. I cut a groove in it with a plasma cutter which will sit over the body seam where the lifting point is. This allows me to jack the car up without busting the skirts. As for servicing, I have found someone that'll let me use his 4 post hoist.
No. But if I get around to it I'll upload some here.Any photos ?
