GonadzInStrife
- Jan 17, 2024
- 5
- 0
- 1
- Age
- 34
- Location
- Victoria
- VE SSV UTE
Ok i recently attempted my first dismantle of the driver head to machine the valve seat, i have successfully put my engine back together and now have a LIMP MODE and reduced power. I believe its due to the MAP sensor cable which the male connector is just 2 metal crimped parts and a rubber ring no "male organ "
So I have researched and everywhere i look the connection for an LS2 engine MAP SENSOR looks completely different and would not fit my plug on the manifold as this is this next picture is the female end.
Can anyone please tell me a solution to this problem and why everywhere online looks so different and nothing makes sense.
here is the results i find for the so called same connector brand new below
WHY DOES IT LOOK SO DIFFERENT TO THE CONECTION I NEED?
1. Do I need to replace the female end in the manifold to buy a cheap solution, or can i buy the correct connector
2. Does anyone no where to find the right connection plug
3. If I change the MAP sensor in the manifold to suit a new plug will that do anything to my LIMP MODE or Computer and make my life harder.
4. Can i just go to a wreckers and cut one off a broken wire loom and use that plug and will it be the same as mine if somehow looks different everywhere else?
5. would the likes of Jaycar sell this connection point?
Any assistance would be handy at this point.
