lmoengnr
Donating Member
- Jan 15, 2012
- 7,097
- 47,500
- 113
- Location
- Sunbury Vic.
- MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Let it breathe, both in and out, then get it tuned.
I have no doubt what your saying is 100% true but it sounds like your over thinking it mate... a decent Otr (vcm brand) extractors (either 4 into 1 or tri Y) hi flow cats and 2.5 inch or 3 inch exhaust system with a good dyno tune will see some really good gains I have much the same car as the op (07 manual) with the above mods and it goes really well better power and torque everywhere compared to stockDirk you are gonna get general comments per above exclaiming that to increase peak rpm HP - derestrict and bigger in/out for better flow - no matter what you ask as the OP lol!
But the case for big bore bolt-ons for max flow at high RPM is opposite to building torque for the operating range (before MBT) as you detailed above. ie better flowing bolt-ons are counterproductive before MBT.
Best advice from years of building highly flexible tune with daily logging for EFIlive focus group using variable valve timing and the torque model, is above. Best simple advice is torque monster cam and gears.
Yes sure some gains compared to Stock, but the shape of the curve should be majorly different with derestricted flow enhancements for more HP up top. If it’s not then it’s not credible.I have no doubt what your saying is 100% true but it sounds like your over thinking it mate... a decent Otr (vcm brand) extractors (either 4 into 1 or tri Y) hi flow cats and 2.5 inch or 3 inch exhaust system with a good dyno tune will see some really good gains I have much the same car as the op (07 manual) with the above mods and it goes really well better power and torque everywhere compared to stock
Yes I’ve seen that, don’t really have much more to add apart from that which I’ve said on the half dozen postings of it as gospel over past several years. You know, apart from the fact it proves what it does, which is not that any size dimension is better than the other. Nor that tri-ys make less HP up top than straight pipes gathered.http://www.ozgarage.com.au/season2-video/season-2-episode-9-online-exhaust-comparo
Unfortunately videos not working for me and i didnt realise it was a 6.3 not a 6. But this is the back to back testing video i saw hopefully on a pc it works.
