dufus
Donating Member
- Jun 9, 2006
- 1,571
- 66
- 0
- rickshaw
What is a bottle of Nulon worth?
A bottle of 20W/50 costs around the $35 mark
Actually not a lot of places, if any, release info on their additive packages, because that is their research and development and is worth too much to them. Others in the industry might have some background knowledge though.
Ok here it is
Nulon does contain PTFE.
PTFE is used inplace of the more commonly used Zinc as an anti wear additive
PTFE is not considered a friction modifier, so I was waaaay off track there
PTFE is not very heat resistant. At approx 472 (I Believe) degrees celcius, PFTE degrades to the point of non effectiveness. Therefore cannot remain where most needed- the upper cylinder & head of the engine.
1970's (could have been 1978 I was told) dow corning released a document stating that they would not back any claims of effectiveness in automotove applications. Back in the 70's and it's still being used.
The information I received says that PFTE is not so much detrimental to an engine, but rather not effective. It may give a slight power increase, but ultimately means that upper cylinder and the head are unprotected from wear by the PFTE due to extreme heat.
Don't go dumping it immediately, but I would be hesitant in using it again.
BRad
Bill
I was going to suggest one bit its a bit more exy than what your using now
Minux, that's interesting. She's a person I'd love to have an audience with for an hour or two.....
Did she say anything about gearboxes, final drives and diffs?
Um, not quite.
The oil (I'm not sure of the actual quality of the oil, so I'll assume it will withstand normal temps and pressures- but maybe not if you say she was rattly after towing) should not degrade more than normal at those temperatures.
However, the ANTI FRICTION ADDITIVE, in this case PTFE, does degrade at (I believe) 472 degrees C.
Anti friction additives are blended into oil for one reason only. When the oil fails.
When 2 metal parts are being separated by oil, everything works as it should. If that oil fails, and the metal parts come together, the anti friction additive stoppes the metal parts wearing, or at least reduces the wear.
PTFE, as it is burned off above 472 degrees c means that when the metal parts come together, there is nothing left to stop that wear.
So the rattly top end may well be quite a separate issue to the PTFE burning off in the oil. That sounds something like the oil has degraded to the point that it is no longer holding viscosity at temperature
oh to your question- once it burns off, its gone untill you replace it with fresh PTFE in new oil
