[VIC] Motor too tight to start.
kingswood country
Melton
hj kingswood
Repair manual, which was the same as last time also.
Everything went back in the same place it come from.
Sent from your god, for you to worship and give money
kingswood country
Melton
hj kingswood
Well, jumping off 2 cars and turning over by hand hasn't got me anywhere...
Fml!
Anything else I can try before pulling it out again?
Loaded Dice
.... Lets roll.
55
MY12 SSV Redline
Not a solution to your problem, but an answer to your question:
Batteries, multiple batteries but still producing 12V, hook all the +'s together as one, and all the -'s together as one, this is wiring in 'parallel', this would not hurt your car at all, the voltage remains the same, but now has the amps from all to crank.
Turning 2 12V batteries into 24V - hook up one negative terminal or battery 1 to the positive terminal of battery 2, then the remaining + from battery 1 and - from battery 2 to whatever you want to apply 24V to. This is wiring in 'serial'.
kingswood country
Melton
hj kingswood
Ah, will try perhaps tonight, maybe in the morning, I'm thinking of throwing in a stock starter while I'm at it just in case.
Which do you recommend is better?
Loaded Dice
.... Lets roll.
55
MY12 SSV Redline
I would not be applying 24V to your starter motor, I think this would cause the magic smoke to escape.
kingswood country
Melton
hj kingswood
Magic smoke? I like that!
turmoil117
Donating Member
33
Armadale
Vs berlina
It would make it turn really fast for a few seconds hahaha... just like if you connected 24V to a 12V globe, it would make it twice as bright until it died a fiery death after a couple of seconds.
Loaded Dice
.... Lets roll.
55
MY12 SSV Redline
Its magic cos nobody knows how it gets in there, but the one certain thing is once you see it come out, whatever it was doesn't work anymore ;)
kingswood country
Melton
hj kingswood
Yup, done it to a computer when I was kid, at least that's what I remember the switch saying!!
It went POP, and I ran away from it without the parents knowing....
I woulda got my ass branded had the old lady have known!
kingswood country
Melton
hj kingswood
If the other way doesn't work, then I'll be doing that I think, I have a spare, I can use it.
But......
Is the starter the ONLY thing I can cook with that?
