P
Pauldw500
Guest
Called 'low power mode' I'm my car...It's supposed to be called limp home mode, not pull to the curb mode.
Keep in mind that the fault is an issue with the ECU not being totally sure of the actual throttle opening. I would imagine that the engineers picked very conservative limp home setting for a large V8. Limp home on transmission faults can be treated a bit differently.Called 'low power mode' I'm my car...
Trust me, when you drive the streets of London, you don't want to be constantly changing gears. I won't be far off but I think 95% of the cabs back in the day were Automatic. I've just had autos since too...Damn autos.
My VF HSV only shows up to 39.9 as well.My VF Holden is capped at showing a maximum of 39.9ltrs/100kms which is a silly arbitrary display limitation chosen by Holden
Wonder if the VF based HSV has the same limitation as my SSVR LE or whether the HSV calibration actually allows accurate and full instantaneous consumption to be shown
If there is no limitation on HSV’s, that’s rather annoying as I was told it’s not possible to correct the Holden to display accurate fuel consumption information above 39.9… Seems it is possible after all (as must be the case) so I was lied to and the facts were misrepresented
It’s simply Holden’s choice to display inaccurate information on our instrument cluster because Holden couldn’t be faffed fixing their shitty calibration file for our vehicle displays…![]()
Thanks for the heads up.
So the VF instantaneous fuel accuracy was downgraded as compared to the VE? Why, because Holden was embarrassed as to the consumption of the LS3? Revisionism? Political correctness gone crazy…
Really, there no engineering reason to cap the display of the actual consumption rate at 39.9 and this 3rd world problem annoys me![]()
