vc commodore
- Jun 18, 2014
- 10,863
- 13,049
- 113
- Location
- Like the Leyland Brothers
- VC, VH and VY
Redo the ECM and then worry what happens...Until then, your running round in circles
Front of car is up but prior to raising the last was 19ks left. I've left battery disconnected since VC said to reset it, and now car is up at the front (any fuel obv going to the back of tank) and now got the 'low fuel' on the dash so would guess the sensor or whatever it has is working. Could be imagining it but *think* she's idling smoother. I also unplugged and plugged back in the connectors to the front brakes and so far not seen the stabilty control or ABS warning, but certainly early days.Range should reset correctly once you start doing some Km in it
As in reset it, or get it defaulted?
Yes gold and silver open/close in different directions, but altho the car should have a silver, last time I got a GM silver and put it in the car went into low power mode with every foot to the floor. The gold operates the best with the totally random low power trip now and then. As time has gone on the low power trips are less, but still happen so want it sorted one day. Maybe it just needs a reset when the silver is installed to let it learn the parameters itself over working with the set that it had learnt with the gold.there is a idle relearn which resets the stored memory, but it always adjusts so if u have any slight idle changes from dirt layering the TB it adjusts over time, they are same as fuel trims but idle trims, this is why when people clean the TB from the small layer of gunk that builds up that it adjusted to over the years then when its gone it idles high till it relearns, the gold and silver TB use different controllers so best to use the silver that suits, they also operate opposite direction i think ?
Yeah all guessing tho, I have no proof he opened the ECM up. Wouldn't surprise me but yeah dunno.Wasn't there talk of defaulting it because of some other owner stuff assing round with it?
You made mention of it in this post to do with defaulting
https://forums.justcommodores.com.au/threads/my-hsv-clubsport.293978/page-384
