07GTS
- Sep 8, 2013
- 5,123
- 6,999
- 113
- Location
- Australia
- VEGTS BUILT BLOWN E85
actual tank fits more volume close to 80 liters for the 73 usage, there is bout 5 liters before the senders register anything and space above which is why u can drive for 50km before the gauge comes off full, there is a little involved with tank tables primary volume and secondary volume then separate is gauge volume primary and secondary, all have to work together as ive found some small changes can cause issuesI suspect that ‘empty’ is about 10L remaining, so the fuel pump can pick up that fuel? So, the 73L tank is probably treated as a 63L tank for the driver information display?
If I factor in that 10L, the information in the DIC seems to be spot on.
