Well, productive weekend.
Got the dash all welded in, so that's finished. Some of the welds were a bit of a mission. I hate working under a dashboard at the best of times, let alone laying on my back with my head up against the firewall doing plug welds...
I got there in the end though, and believe it or not the welds are perfect (shame no one will ever see them lol).
Fixed a bit of rust in the plenum chamber while the dash was out too. That would have been a bit tedious with the dash in, so i took the opportunity to do it.
I also stripped all the paint off the top of the dash while it was out and easy to do. Once it was all welded in i gave it a coat of satin black to tidy it up a bit. It won't be seen once it's all back together, but i know it's done anyway. The top will get painted properly at a later date.
Dashboard removed, rust cut out
Dash welded in, top back to bare metal
All welded and a coat of paint
Rust repaired and painted
So, with that finished, i moved back to the front end.
I started by cutting the car inner guards to mate up to the front cut inner guards. Then i removed the front end to strip off the paint and get it all prepared for welding. I stripped the entire front cut with paint stripper and a high pressure washer. Once that was done i fitted it all back on for the final time. It's ready to weld on now.
Front removed
All back on after being paint stripped (there is still some primer on the radiator support, but that'll wire wheel off nicely)
The inner guards, once they are welded and finished off you won't even know they have been joined (note the rust repairs where the hinges go).
So, that's where it's at ATM. I'll probably weld the front on this week.
