my vk berlina
ari666
250,000 hits
thought i may as well post this here;
AndyVKSSA
darlington
VR caprice 5ltr, VK group 3 rep 5ltr
all that work and it only made 147.5rwkw?
monsteroz
VZ SS ute and VC sedan
That is a very big carby for a 308
ari666
250,000 hits
monsteroz
biggest problem with too bigger carby is lean problems at high revs.. or you are wasting fuel and down on horses... matched solution is best in this case.. bigger not necessarily better.. GO EFI :)
Sean
ari666
250,000 hits
ari666
250,000 hits
so this weekend was a commitment of re-doing my inlet manifold, because i descovered that i could no longer remove my distributor ?!?! anyways, refitted the manifold without dramas, fitted a 1 inch phenlonic spacer, cut the choke horn off my 650 DP an ground it down nice an flat and fitted that.
only to descover to my dismay that this carby is nowhere near setup for this engine in regards to power valve, jets, pump shots etc. so now i have to go through the whole precess of getting it all working efficiently again.
*sigh*
